Drstation,
Do you have 5 volts d.c. at the BOB ?
See attached image:
Jeff...
hi all
i'm building a 3 axis cnc machine with mdf
it has a work area of appr. x=70 y= 55 z=7.5 cm
when i connected the machine together i found that motors are missing steps locking moving in one direction and not the other or moving in the same direction with different buttons pressed in mach 3
i have a 6 axis parallel port bob RAM Electronics : PC-CNC Parallel Interface Control 6 Axis - Compatible with MACH3 [KIT.BOB.3M] - 500.00L.E.
3 single axis tb6560 drivers and the pc is runnuing on window 7 ultimate 32 bit.
i thought the problem was with drivers as if i connect one driver the moves fine , and if more than one driver the problem happens
however i found that the 5 volts port on the board that is connected to all en pin on the drivers discharges only 2.55 volts when not connected to any driver , 2.1 volts when loaded with one driver (the one motor works fine in this condition) ,1.88 volts when connected to 3 driver (problem in motors movement)
so i thought the problem was with the bob 5 volts port
i called the board supplier and they asked me to send them the board and i did that
they called after 2 days confirming that there is nothing wrong with the board !!!
i did some search and found that i have to check the parallel port voltage
(i found that it discharges 3.4 volts in dir pins ( x dir pin =no .14 y= no.3 z= no.4)
so i changed the parallel port modes (4 modes) in the bios and came with this results
(Standard printer port mode pin 14=4.4 v pin 3=3.3 pin 4=3.3 v)
(EPP+ECP mode pin 14=3.4 v pin 3=3.3 pin 4=3.3 v)
(ECP mode pin 14=4.4 v pin 3=3.3 pin 4=3.3 v)
(EPP mode pin 14=3.4 v pin 3=3.3 pin 4=3.3 v)
is the problem here is with the parallel port voltage or with the bob?
and what should i do about it?
Drstation,
See attached image:
Jeff...
hello Jeff,
this 5 volt port gives 2.55 volts reading only with my pc .thats why i called and sent the bob to supplier and they confirmed the reading at 5 volts.
When you disconnect all the limit switches and stepper connections does it have 5 volts d.c.?
disconnecting all connections (even parallel cable) gives zero reading
only connecting parallel cable with no drivers , motors or limit switches connection ( reading 2.55 dc volts)
Simple solution: Purchase a 5 volt power supply and use it to power the logic connections on the stepper drives.
See attached link:
Switching power regulate items in 5V 2A regulated store on eBay!
Jeff...
according to wiring diagram of the bob
i have to connect +5 volts of the board to all + of the driver ( clk,cw.en)
is it safe to get an external 5 volts supply and connect it to clk cw en of the driver (pardon me for asking such question cause i have very little knowledge of electricity and electronics)
Yes it is safe otherwise I would not have suggested doing so.
Connect the negative or (-) minus side of the power supply to the Bob (GND) and the positive or (+) plus side to all of the drivers.
See attached image for external power supply wiring:
Jeff...
See image for external 5 volt power supply wiring connections:
Jeff...
Yes the 5 volts from the computer will work, use the same wiring diagram.
Yes If the enable requires + 5 volts to run the drives however most Chinese stepper drives do not require the enable connections.
A one (1) amp 5 volt d.c. power supply would suffice since the opto isolators only use about 15ma each.
Jeff...
i did the 5 volts wiring as you told me
but no motor moves !!
in the pictures
1--my wiring (diagram.jpg)
2--the board with 220 v supply( FIPBOB3M (1).jpg)
3--the driver wiring manual (HCMODU0022_BL_TB6560_V2_Single_Axis_Stepper_Motor _Controller_Diagram)
am i doing somethin wrong?
Try removing the power from the enable connection.
Do you have motion now?
i just did that but still no movement !
Add an additional ground wire, see attached image:
- - - Updated - - -
Does the motor lockup when power is applied to the stepper drive?
The ground needs a common connection between all boards.
and do not connect power to the enable connection
Are you sure the new power supply provides clean reliable 5 volts d.c.?
